Create a Vscan On-Demand policy
Creates a Vscan On-Demand policy to initiate virus scanning tasks on a data SVM. This policy allows you to specify scan paths and schedules, providing control over when and where scans occur to ensure system security.
HTTP method and endpoint
POST /protocols/vscan/{svm.uuid}/on-demand-policies
Introduced in
ONTAP 9.6
Usage notes
Created only on a data SVM.
Important notes:
Only one policy can be scheduled at a time on an SVM. Use schedule name or schedule uuid to schedule an On-Demand policy.
Scanning must be enabled on the SVM before the policy is scheduled to run.
The exclude_extensions setting overrides the include_extensions setting. Set scan_without_extension to true to scan files without extensions.
Required properties
svm.uuid- Existing SVM in which to create the Vscan On-Demand policy. -
name- Name of the Vscan On-Demand policy. Maximum length is 256 characters. -
log_path- Path from the Vserver root where the On-Demand policy report is created. -
scan_paths- List of paths that need to be scanned.
Recommended optional properties
schedule- Scan schedule. It is recommended to set the schedule property, as it dictates when to scan for viruses.
Default property values
If not specified in POST, the following default property values are assigned:
include_extensions- * -
max_file_size- 10737418240 -
scan_without_extension- true
Related ONTAP commands
vserver vscan on-demand-task create -
vserver vscan on-demand-task schedule
return_records |
boolean |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
log_path |
string |
The path from the Vserver root where the task report is created. |
name |
string |
On-Demand task name |
scan_paths |
array[string] |
List of paths that need to be scanned. |
schedule |
Schedule of the task. |
scope |
svm |
Example request
"log_path": "/vol0/report_dir",
"name": "task-1",
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"schedule": {
"name": "weekly",
"scope": {
"exclude_extensions": [
"mp3",
"mp4"
"exclude_paths": [
"/vol1/cold-files/",
"/vol1/cifs/names"
"include_extensions": [
"vmdk",
"mp*"
"max_file_size": 10737418240
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[vscan_on_demand] |
"num_records": 1,
"records": [
"name": "task-1",
"scan_paths": [
"/vol1/",
"/vol2/cifs/"
"schedule": {
"name": "weekly",
"scope": {
"mp3",
"mp4"
"exclude_paths": [
"/vol1/cifs/names"
"vmdk",
"mp*"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10027101 |
The file size must be in the range 1KB to 1TB |
10027107 |
The include extensions list cannot be empty. Specify at least one extension for inclusion. |
10027164 |
An On-Demand policy cannot be scheduled, as the Vscan is disabled. Enable the Vscan and retry the operation. |
10027167 |
The specified schedule does not exist. Create the schedule or create a policy without specifying the schedule. |
10027168 |
The specified scan path does not exist. The scan path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use “/” not “\”) |
10027169 |
The specified scan path is not supported for scanning. |
10027173 |
The new On-Demand policy cannot be created as the SVM has reached the maximum number of On-Demand policies allowed. Delete an existing policy in order to create a new policy. |
10027174 |
The specified exclude path is invalid. The path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use "/" not "\") |
10027175 |
An On-Demand policy cannot be scheduled as the Vserver is not in an operational state. |
10027176 |
The log-path specified does not exist. The log path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use “/” not “\”). |
10027177 |
The log path specified is not supported. |
| 10027178 | The specified task-name is invalid. Valid characters are 0-9, A-Z, a-z, "_", ".", and "-" | 10027253 | The number of paths specified exceeds the configured maximum number of paths. You cannot specify more than the maximum number of configured paths. | | 10027254 | The number of extensions specified exceeds the configured maximum number of extensions. You cannot specify more than the maximum number of configured extensions. | | 10027255 | Another policy is already scheduled. Only one policy per SVM is allowed to be scheduled at any one time. Create a policy without specifying a schedule. |
href |
string |
_links
schedule
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
scope
exclude_extensions |
array[string] |
List of file extensions for which scanning is not performed. |
exclude_paths |
array[string] |
List of file paths for which scanning must not be performed. |
include_extensions |
array[string] |
List of file extensions to be scanned. |
max_file_size |
integer |
Maximum file size, in bytes, allowed for scanning. |
scan_without_extension |
boolean |
Specifies whether or not files without any extension can be scanned. |
svm
name |
string |
uuid |
string |
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path |
string |
name |
string |
scan_paths |
array[string] |
schedule |
scope |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
