REST API reference
Restore keys for an SVM from a configured AWS KMS
Restores the keys for an SVM from a configured AWS Key Management Service (KMS) to manage secure access to your storage resources.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/restore
Introduced in
ONTAP 9.12
Usage notes
Restores the keys for an SVM from a configured AWS KMS.
  • security key-manager external AWS restore
aws_kms.uuid
string
path
True
UUID of the existing AWS KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65536082
Unable to restore all keys.
65537544
Missing wrapped top-level internal key protection key (KEK) from internal database.
65537926
The Amazon Web Service Key Management Service is not configured for the given SVM.
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
