Restore keys for an SVM from a configured AWS KMS
Restores the keys for an SVM from a configured AWS KMS to reinstate secure access to your data.
HTTP method and endpoint
POST /security/aws-kms/{aws_kms.uuid}/restore
Introduced in
ONTAP 9.12
Related ONTAP commands
security key-manager external AWS restore
aws_kms.uuid |
string |
path |
True |
UUID of the existing AWS KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536082 |
Unable to restore all keys. |
65537544 |
Missing wrapped top-level internal key protection key (KEK) from internal database. |
65537926 |
The Amazon Web Service Key Management Service is not configured for the given SVM. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
