REST API reference
Sign security certificates
Signs a certificate request using a pre-existing self-signed root certificate, which acts as a certificate authority. This operation is typically performed to manage certificate authentication within its scope, ensuring secure communications.
HTTP method and endpoint
POST /security/certificates/{ca.uuid}/sign
Introduced in
ONTAP 9.6
Required properties
  • signing_request - Certificate signing request to be signed by the given certificate authority.
  • expiry_time - Certificate expiration time. Specifying an expiration time for a signed certificate is recommended.
  • hash_function - Hashing function. Specifying a strong hashing function is recommended when signing a certificate.
Default property values
If not specified in POST, the following default property values are assigned:
  • expiry_time - P365DT
  • hash_function - sha256
  • security certificate sign This API is used to sign a certificate request using a pre-existing self-signed root certificate. The self-signed root certificate acts as a certificate authority within its scope and maintains the records of its signed certificates.
The root certificate can be created for a given SVM or for the cluster using [POST security/certificates].
ca.uuid
string
path
True
UUID of the existing certificate authority certificate
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
expiry_time
string
Certificate expiration time. The allowed expiration time range is between 1 day to 10 years.
hash_function
string
Hashing function
signing_request
string
Certificate signing request to be signed by the given certificate authority. Request should be in X509 PEM format.
Example request
  "expiry_time": "string",
  "hash_function": "string",
  "signing_request": "<CERTIFICATE-CONTENT>"
Status: 200, Ok
public_certificate
string
CA signed public key Certificate
  "public_certificate": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
3735628
Failed to use CA certificate for signing.
3735665
The specified hash function is not supported in FIPS mode.
52559974
The certificate is not supported in FIPS mode.
3735626
Failed to generate signed Certificate.
3735558
Failed to extract information about Common Name from the certificate.
3735588
The common name (CN) extracted from the certificate is not valid.
3735632
Failed to extract Certificate Authority Information from the certificate.
3735629
Failed to sign the certificate because Common Name of signing certificate and Common Name of CA certificate are same.
3735630
Failed to sign the certificate because expiry date of signing certificate exceeds the expiry date of CA certificate.
security_certificate_sign
expiry_time
string
hash_function
string
Hashing function
signing_request
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
