Sign security certificates
POST /security/certificates/{ca.uuid}/sign
Introduced In: 9.6
Signs a certificate.
Required properties
signing_request- Certificate signing request to be signed by the given certificate authority.
Recommended optional properties
expiry_time- Certificate expiration time. Specifying an expiration time for a signed certificate is recommended. -
hash_function- Hashing function. Specifying a strong hashing function is recommended when signing a certificate.
Default property values
If not specified in POST, the following default property values are assigned:
expiry_time- P365DT -
hash_function- sha256
Related ONTAP commands
security certificate signThis API is used to sign a certificate request using a pre-existing self-signed root certificate. The self-signed root certificate acts as a certificate authority within its scope and maintains the records of its signed certificates.
The root certificate can be created for a given SVM or for the cluster using [POST security/certificates].
ca.uuid |
string |
path |
True |
UUID of the existing certificate authority certificate |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
expiry_time |
string |
Certificate expiration time, in ISO 8601 duration format or date and time format. The allowed expiration time range is between 1 day to 10 years. |
hash_function |
string |
Hashing function |
signing_request |
string |
Certificate signing request to be signed by the given certificate authority. Request should be in X509 PEM format. |
Example request
"expiry_time": "P1DT2H3M4S or '2030-01-25T11:20:13Z'",
"hash_function": "string",
"signing_request": "'-----BEGIN CERTIFICATE REQUEST----- MIICYDCCAUgCAQAwGzEMMAoGA1UEAxMDQUJDMQswCQYDVQQGEwJVUzCCASIwDQYJ KoZIhvcNAQEBBQADggEPADCCAQoCggEBAPF+82SlqT3Vyu3Jx4IAwHcO5EGwLOxy zQ6KNjz71Fca0n1/A1CbCPyOsSupGVObvdWxX7xLVMJ2SXb7h43GCqYyX6FXJO4F HOpmLvB+jxdeiW7SDbiZyLUlsvA+oRO/uNlcug773QZdKLjJD64erZZMRUNbUJB8 bARxAUi0FPvgTraSQ0UW5sRLiGKeAyKA4wekYe1VgjHRTBizFbD4dI3njfva/2Bl jf+kkulgcLJTuJNtkgeimqMKyraYuleYcYk2K+C//0NuNOuPbDfTXCM7O61vik09 Szi8nLN7OXE9KoAA93U/BCpSfpl8XIb4cGnEr8hgVHOOtZSo+KZBFxMCAwEAAaAA MA0GCSqGSIb3DQEBCwUAA4IBAQC2vFYpvgsFrm5GnPx8tOBD1xsTyYjbWJMD8hAF lFrvF9Sw9QGCtDyacxkwgJhQx8l8JiIS5GOY6WWLBl9FMkLQNAhDL9xF3WF7vfYq RKgrz3bd/Vg96fsRZNYIPLGmoEaqLOh3FOCGc2VbdsR9PwOn3fwthxkIRd6ds6/q jc5cpSmVsCOgu+OKcpRXikYDbkWXfTZ1AhSfn6njBYFdZ9+PNAu/0JRQh5bX60nO 5heniTcAJLwUZP/CQ8nxHY0Wqy+1rAtM33d5cVmhUlBXQSIru/0ZkA/b9fK5Zv8E ZMADYUoEvIG59Vxhyci8lzYf+Mxl8qBSF+ZdC4yWhzDqZtM9 -----END CERTIFICATE REQUEST-----'"
Status: 200, Ok
public_certificate |
string |
CA signed public key Certificate |
"public_certificate": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3735628 |
Failed to use CA certificate for signing. |
3735665 |
The specified hash function is not supported in FIPS mode. |
52559974 |
The certificate is not supported in FIPS mode. |
3735626 |
Failed to generate signed Certificate. |
3735558 |
Failed to extract information about Common Name from the certificate. |
3735588 |
The common name (CN) extracted from the certificate is not valid. |
3735632 |
Failed to extract Certificate Authority Information from the certificate. |
3735629 |
Failed to sign the certificate because Common Name of signing certificate and Common Name of CA certificate are same. |
3735630 |
Failed to sign the certificate because expiry date of signing certificate exceeds the expiry date of CA certificate. |
3735701 |
Invalid expiration period. The allowed range for expiration time is between 1 and 3652 days. |
security_certificate_sign
expiry_time |
string |
hash_function |
string |
Hashing function |
signing_request |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
