REST API reference
Re-key the internal key in the key hierarchy for an SVM
Rekeys the internal key for an SVM using a Google Cloud KMS configuration, ensuring secure key management in your storage environment.
HTTP method and endpoint
POST /security/gcp-kms/{uuid}/rekey-internal
Introduced in
ONTAP 9.10
Usage notes
Rekeys the internal key in the key hierarchy for an SVM with a Google Cloud KMS configuration.
  • security key-manager external gcp rekey-internal
uuid
string
path
True
UUID of the existing Google Cloud KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537547
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation.
65537559
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys.
65537721
Google Cloud KMS is not configured for the given SVM.
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
