Re-key the internal key in the key hierarchy for an SVM
Rekeys the internal key in the key hierarchy for an SVM that uses a Google Cloud KMS configuration. This is available exclusively through NetApp Cloud Volume Services for GCP.
HTTP method and endpoint
POST /security/gcp-kms/{gcp_kms.uuid}/rekey-internal
Introduced in
ONTAP 9.9
Usage notes
Rekeys the internal key in the key hierarchy for an SVM with a Google Cloud KMS configuration. Note: This method is only available to the NetApp Cloud Volume Services for GCP.
Related ONTAP commands
security key-manager external gcp rekey-internal
gcp_kms.uuid |
string |
path |
True |
UUID of the existing Google Cloud KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537559 |
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys. |
65537721 |
Google Cloud KMS is not configured for the given SVM. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
