Create a multi-admin-verify rule
Creates a multi-admin-verify rule to manage administrative actions that require multiple approvals. Use this endpoint to configure rules that enhance security and control over critical operations.
HTTP method and endpoint
POST /security/multi-admin-verify/rules
Introduced in
ONTAP 9.11
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
approval_expiry |
string |
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used. |
approval_groups |
array[approval_groups] |
List of approval groups that are allowed to approve requests for rules that don't have approval groups. |
auto_request_create |
boolean |
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
create_time |
string |
execution_expiry |
string |
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used. |
operation |
string |
Command that requires one or more approvals. |
owner |
The owner of the rule. The only valid owner is currently the cluster. |
query |
string |
When specified, this property limits the entries that require approvals to those that match the specified query. |
required_approvers |
integer |
The number of required approvers, excluding the user that made the request. |
system_defined |
boolean |
Specifies whether the rule is system-defined or user-defined. |
Example request
"approval_expiry": "string",
"approval_groups": [
"name": "string"
"create_time": "string",
"execution_expiry": "string",
"operation": "string",
"owner": {
"name": "svm1",
"query": "string"
Status: 201, Created
num_records |
integer |
Number of records |
records |
array[multi_admin_verify_rule] |
"num_records": 1,
"records": [
"name": "string"
"owner": {
"name": "svm1",
"query": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262148 |
The specified command is not recognized. |
262308 |
The specified command is not supported by this feature. |
262309 |
The feature must be enabled first. |
262311 |
Value must be greater than zero. |
262312 |
Number of required approvers must be less than the total number of unique approvers in the approval-groups. |
262313 |
Number of unique approvers in the approval-groups must be greater than the number of required approvers. |
262314 |
Some approval-groups were not found. |
262316 |
Value must be in the range one second to two weeks. |
262326 |
Failed to parse query. |
262335 |
The query string must be contained in either the "operation" or "query" parameters but not in both. |
approval_groups
name |
string |
Name of the approval group. |
href |
string |
_links
owner
name |
string |
The name of the SVM. |
uuid |
string |
approval_expiry |
string |
approval_groups |
boolean |
create_time |
string |
execution_expiry |
string |
operation |
string |
owner |
query |
string |
integer |
system_defined |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
