REST API reference
Create a multi-admin-verify rule
Creates a multi-admin-verify rule to define the conditions under which multiple administrator approvals are required for certain operations. This helps enhance the security and control of administrative actions.
HTTP method and endpoint
POST /security/multi-admin-verify/rules
Introduced in
ONTAP 9.11
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
approval_expiry
string
Time for requests to be approved, in ISO-8601 duration format. If not set, the global setting is used.
approval_groups
array[approval_groups]
List of approval groups that are allowed to approve requests for rules that don't have approval groups.
auto_request_create
boolean
When true, ONTAP automatically creates a request for any failed operation where there is no matching pending request.
  • Default value: 1
  • Introduced in: 9.11
  • x-nullable: true
create_time
string
execution_expiry
string
Time for requests to be executed once approved, in ISO-8601 duration format. If not set, the global setting is used.
operation
string
Command that requires one or more approvals.
owner
owner
The owner of the rule. The only valid owner is currently the cluster.
query
string
When specified, this property limits the entries that require approvals to those that match the specified query.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
system_defined
boolean
Specifies whether the rule is system-defined or user-defined.
Example request
  "approval_expiry": "string",
  "approval_groups": [
      "name": "string"
  "create_time": "string",
  "execution_expiry": "string",
  "operation": "string",
  "owner": {
    "name": "svm1",
  "query": "string"
Status: 201, Created
num_records
integer
Number of records
records
array[multi_admin_verify_rule]
  "num_records": 1,
  "records": [
          "name": "string"
      "owner": {
        "name": "svm1",
      "query": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262148
The specified command is not recognized.
262308
The specified command is not supported by this feature.
262309
The feature must be enabled first.
262311
Value must be greater than zero.
262312
Number of required approvers must be less than the total number of unique approvers in the approval-groups.
262313
Number of unique approvers in the approval-groups must be greater than the number of required approvers.
262314
Some approval-groups were not found.
262316
Value must be in the range two minutes to two weeks.
262326
Failed to parse query.
262335
The query string must be contained in either the "operation" or "query" parameters but not in both.
approval_groups
name
string
Name of the approval group.
string
owner
name
string
The name of the SVM. This field cannot be specified in a POST or PATCH method.
uuid
string
approval_expiry
string
approval_groups
auto_request_create
boolean
  • Default value: 1
  • x-nullable: true
create_time
string
execution_expiry
string
operation
string
owner
owner
query
string
required_approvers
integer
system_defined
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
