Create a configuration backup
Creates a configuration backup, which is essential for preserving your system settings and ensuring you can restore them when needed.
HTTP method and endpoint
POST /support/configuration-backup/backups
Introduced in
ONTAP 9.7
Usage notes
The required backup file name must end with .7z extension.
Required properties
node.uuidornode.name- The node UUID or node name on which the configuration backup will be created. -
name- The backup file name
Related ONTAP commands
system configuration backup create
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
auto |
boolean |
Indicates if the backup was created automatically. |
backup_nodes |
array[backup_node] |
The list of nodes included in the backup. |
download_link |
string |
The link to download the backup file. |
name |
string |
The backup name. |
node |
The node that owns the configuration backup. |
size |
integer |
The size of the backup in bytes. |
time |
string |
The backup creation time. |
type |
string |
The backup type. |
version |
string |
The software version. |
Example request
"backup_nodes": [
"name": "string"
"download_link": "https://10.224.65.198/backups/backup_file.7z",
"name": "backup_file.7z",
"node": {
"name": "node1",
"size": 4787563,
"time": "2019-02-04T13:33:48-05:00",
"type": "string",
"version": "9.7.0"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5963818 |
Failed to queue private job. |
5963819 |
Failed to queue cluster job. |
5963871 |
Requested backup name is missing .7z suffix. |
backup_node
The node name in the backup.
name |
string |
href |
string |
_links
node
_links |
name |
string |
uuid |
string |
configuration_backup_file
The configuration backup file.
auto |
boolean |
backup_nodes |
download_link |
string |
name |
string |
The backup name. |
node |
size |
integer |
time |
string |
type |
string |
The backup type. |
version |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
