REST API reference
Create a configuration backup
Creates a configuration backup to preserve the current state of your system settings. Use this endpoint to generate a backup file with a .7z extension, ensuring you have a restore point for system configurations.
HTTP method and endpoint
POST /support/configuration-backup/backups
Introduced in
ONTAP 9.7
Usage notes
The required backup file name must end with .7z extension.
Required properties
  • node.uuid or node.name - The node UUID or node name on which the configuration backup will be created.
  • name - The backup file name
  • system configuration backup create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
auto
boolean
Indicates if the backup was created automatically.
backup_nodes
array[backup_node]
The list of nodes included in the backup.
download_link
string
The link to download the backup file.
name
string
The backup name.
node
node
The node that owns the configuration backup.
size
integer
The size of the backup in bytes.
time
string
The backup creation time.
type
string
The backup type.
version
string
The software version.
Example request
  "backup_nodes": [
      "name": "string"
  "download_link": "https://10.224.65.198/backups/backup_file.7z",
  "name": "backup_file.7z",
  "node": {
    "name": "node1",
  "size": "4787563",
  "time": "2019-02-04T13:33:48-05:00",
  "type": "string",
  "version": "9.7.0"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
5963818
Failed to queue private job.
5963819
Failed to queue cluster job.
5963871
Requested backup name is missing .7z suffix.
backup_node
The node name in the backup.
name
string
string
node
name
string
uuid
string
configuration_backup_file
The configuration backup file.
auto
boolean
backup_nodes
array[backup_node]
download_link
string
name
string
The backup name.
node
node
size
integer
time
string
type
string
The backup type.
version
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
