Create a new SVM peer relationship
Creates a new SVM peer relationship to establish connectivity between storage virtual machines for data transfer operations. This is useful when setting up replication or other peering applications across different SVMs.
HTTP method and endpoint
POST /svm/peers
Introduced in
ONTAP 9.6
Important notes
The create request accepts peer SVM name as input instead of peer SVM UUID as the local cluster cannot validate peer SVM based on UUID.
The input parameter
namerefers to the local name of the peer SVM. Thepeer cluster nameparameter is optional for creating intracluster SVM peer relationships.
Required properties
svm.nameorsvm.uuid- SVM name or SVM UUID -
peer.svm.nameorpeer.svm.uuid- Peer SVM name or Peer SVM UUID -
peer.cluster.nameorpeer.cluster.uuid- Peer cluster name or peer cluster UUID -
applications- Peering applications
Related ONTAP commands
vserver peer create
Example
Creates a new SVM peer relationship.
POST "/api/svm/peers" '{"svm":{"name":"vs1"}, "peer.cluster.name":"cluster2", "peer.svm.name":"VS1", "applications":["snapmirror"]}'
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
applications |
array[string] |
A list of applications for an SVM peer relation. |
force |
boolean |
Use this to suspend, resume or delete the SVM peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues. |
name |
string |
A peer SVM alias name to avoid a name conflict on the local cluster. |
peer |
Details for a peer SVM object. |
svm |
Local SVM details |
uuid |
string |
SVM peer relation UUID |
Example request
"applications": [
"snapmirror",
"lun_copy"
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
"svm": {
"name": "svm1",
"uuid": "string"
Status: 202, Accepted
applications |
array[string] |
force |
boolean |
name |
string |
peer |
svm |
Local SVM details |
uuid |
string |
"applications": [
"snapmirror",
"lun_copy"
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"svm": {
"name": "svm1",
"svm": {
"name": "svm1",
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434889 |
Internal error. Wait and retry. |
26345575 |
The specified peer cluster name and peer cluster UUID do not match. |
26345579 |
The specified field is invalid. |
26345580 |
SVM name or SVM UUID must be provided. |
href |
string |
_links
cluster
_links |
name |
string |
uuid |
string |
svm
name |
string |
The name of the SVM. |
uuid |
string |
peer
cluster |
svm |
svm
Local SVM details
name |
string |
uuid |
string |
svm_peer
An SVM peer relation object.
applications |
array[string] |
force |
boolean |
name |
string |
peer |
svm |
Local SVM details |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
