REST API reference
Create a new SVM peer relationship
Creates a new SVM peer relationship to establish a connection between SVMs for data transfer and management tasks. This is typically used to facilitate data replication or backup operations across different SVMs within a cluster.
HTTP method and endpoint
POST /svm/peers
Introduced in
ONTAP 9.6
Important notes
  • The create request accepts peer SVM name as input instead of peer SVM UUID as the local cluster cannot validate peer SVM based on UUID.
  • The input parameter name refers to the local name of the peer SVM. The peer cluster name parameter is optional for creating intracluster SVM peer relationships.
Required properties
  • svm.name or svm.uuid - SVM name or SVM UUID
  • peer.svm.name or peer.svm.uuid - Peer SVM name or Peer SVM UUID
  • peer.cluster.name or peer.cluster.uuid - Peer cluster name or peer cluster UUID
  • applications - Peering applications
  • vserver peer create
Example
Creates a new SVM peer relationship.
POST "/api/svm/peers" '{"svm":{"name":"vs1"}, "peer.cluster.name":"cluster2", "peer.svm.name":"VS1", "applications":["snapmirror"]}'
Learn more
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
applications
array[string]
A list of applications for an SVM peer relationship.
force
boolean
Use this to suspend, resume or delete the SVM peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues.
name
string
A peer SVM alias name to avoid a name conflict on the local cluster.
peer
peer
Details for a peer SVM object.
svm
svm
Local SVM details
uuid
string
SVM peer relationship UUID
Example request
  "applications": [
    "snapmirror",
    "lun_copy"
  "name": "string",
  "peer": {
    "cluster": {
      "name": "cluster2",
      "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
    "svm": {
      "name": "svm1",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error codes Description
13434889
Internal error. Wait and retry.
26345575
The specified peer cluster name and peer cluster UUID do not match.
26345579
The specified field is invalid.
26345580
SVM name or SVM UUID must be provided.
9896086
Peer SVM name conflicts with one of the following: a peer SVM in an existing SVM peer relationship, a local SVM, or an IPSpace. Use the "name" property to uniquely specify the peer SVM alias name.
9895996
Cannot specify lun-copy as an inter-cluster application.
9896093
The flexcache application is not supported on this platform.
9896095
SVM name is in use by a peer Vserver in a Vserver peer relationship.
string
cluster
name
string
uuid
string
svm
name
string
uuid
string
peer
cluster
cluster
svm
svm
svm
Local SVM details
name
string
uuid
string
svm_peer
An SVM peer relationship object.
applications
array[string]
force
boolean
name
string
peer
peer
svm
svm
Local SVM details
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
