Storage switches endpoint overview
Retrieving storage switch information
The storage switch GET API retrieves all of the switches in the cluster.
1) Retrieves a list of storage switches from the cluster
The following example shows the response with a list of storage switches in the cluster:
# The API: /api/storage/switches # The call: curl -X GET "https://<mgmt-ip>/api/storage/switches" -H "accept: application/hal+json" # The response: { "records": [ { "name": "Brocade_10.226.57.206", "_links": { "self": { "href": "/api/storage/switches/Brocade_10.226.57.206" } } }, { "name": "Brocade_10.226.57.207", "_links": { "self": { "href": "/api/storage/switches/Brocade_10.226.57.207" } } }, { "name": "Brocade_10.226.57.208", "_links": { "self": { "href": "/api/storage/switches/Brocade_10.226.57.208" } } }, { "name": "Brocade_10.226.57.209", "_links": { "self": { "href": "/api/storage/switches/Brocade_10.226.57.209" } } } ], "num_records": 4, "_links": { "self": { "href": "/api/storage/switches/" } } }
2) Retrieves a specific storage switch from the cluster
The following example shows the response of the requested storage switch. If there is no storage switch with the requested name, an error is returned.
# The API: /api/storage/switches/{name} # The call: curl -X GET "https://<mgmt-ip>/api/storage/switches/Brocade_10.226.57.206" -H "accept: application/hal+json" # The response: { "name": "Brocade_10.226.57.206", "domain_id": 5, "switch_fabric_name": "100050eb1a238892", "fw_version": "v7.2.1c1", "ip_address": "10.226.57.206", "is_director_class": false, "local": false, "monitoring_enabled": true, "model": "Brocade6510", "role": "subordinate", "state": "ok", "symbolic_name": "rtp-fc01-41kk11", "vendor": "brocade", "wwn": "100050eb1a1ef7d7", "power_supply_units": [ { "name": "Power Supply #1", "state": "ok" }, { "name": "Power Supply #2", "state": "ok" } ], "temperature_sensors": [ { "name": "SLOT #0: TEMP #1", "reading": 52, "state": "ok" } ], "ports": [ { "name": "FC port 0/0", "mode": "f_port", "wwn": "200050eb1a1ef7d7", "enabled": true, "state": "online", "speed": 16, "sfp": { "type": "small_form_factor", "transmitter_type": "short_wave_laser", "serial_number": "HAA2140310058E5" } }, { "name": "FC port 0/1", "mode": "f_port", "wwn": "200050eb1a1ef2d7", "enabled": true, "state": "online", "speed": 16, "sfp": { "type": "small_form_factor", "transmitter_type": "short_wave_laser", "serial_number": "HAA2140310058E5" } }, { "name": "FC port 0/2", "mode": "f_port", "wwn": "200050eb1a1ef7d0", "enabled": true, "state": "online", "speed": 16, "sfp": { "type": "small_form_factor", "transmitter_type": "short_wave_laser", "serial_number": "HAA2140310058E5" } }, { "name": "FC port 0/3", "mode": "f_port", "wwn": "200050eb1a1ef7d7", "enabled": true, "state": "online", "speed": 16, "sfp": { "type": "small_form_factor", "transmitter_type": "short_wave_laser", "serial_number": "HAA2140310058E5" } }, { "name": "FC port 0/4", "mode": "f_port", "wwn": "200050eb1a1ef2d7", "enabled": true, "state": "online", "speed": 16, "sfp": { "type": "small_form_factor", "transmitter_type": "short_wave_laser", "serial_number": "HAA2140310058E5" } }, { "name": "FC port 0/5", "mode": "f_port", "wwn": "200050eb1a1ef7d0", "enabled": true, "state": "online", "speed": 16, "sfp": { "type": "small_form_factor", "transmitter_type": "short_wave_laser", "serial_number": "HAA2140310058E5" } } ], "connections": [ { "source_port": { "name": "FC port 0/0", "wwn": "200050eb1a236efd", "mode": "f_port" }, "peer_port": { "wwn": "2100000e1e30ac5f", "connection": "sti8020mcc-htp-006:fcvi_device_1", "type": "fcvi_adapter", "unique_id": "38993dc0-4ea1-11eb-9331-00a0985bd455" } }, { "source_port": { "name": "FC port 0/1", "wwn": "200150eb1a236efd", "mode": "f_port" }, "peer_port": { "wwn": "21000024ff72c0c9", "connection": "sti8020mcc-htp-006:2b", "type": "fcp_adapter", "unique_id": "38993dc0-4ea1-11eb-9331-00a0985bd455" } }, { "source_port": { "name": "FC port 0/2", "wwn": "200250eb1a236efd", "mode": "f_port" }, "peer_port": { "wwn": "21000024ff72c0cb", "connection": "sti8020mcc-htp-006:2d", "type": "fcp_adapter", "unique_id": "38993dc0-4ea1-11eb-9331-00a0985bd455" } } ], "fans": [ { "name": "FAN #1", "speed": 7336, "state": "ok" }, { "name": "FAN #2", "speed": 7336, "state": "ok" } ], "paths": [ { "adapter": { "name": "2a", "wwn": "21000024ff6c4bc0", "type": "fcp_initiator" }, "port": { "name": "FC port 0/4", "speed": 8 }, "node": { "name": "sti8020mcc-htp-005", "uuid": "382cb083-4416-11eb-ad1d-00a0985bd455", "_links": { "self": { "href": "/api/cluster/nodes/382cb083-4416-11eb-ad1d-00a0985bd455" } } }, "_links": { "self": { "href": "/api/storage/ports/382cb083-4416-11eb-ad1d-00a0985bd455/2a" } } }, { "adapter": { "name": "2c", "wwn": "21000024ff6c4bc2", "type": "fcp_initiator" }, "port": { "name": "FC port 0/5", "speed": 8 }, "node": { "name": "sti8020mcc-htp-005", "uuid": "382cb083-4416-11eb-ad1d-00a0985bd455", "_links": { "self": { "href": "/api/cluster/nodes/382cb083-4416-11eb-ad1d-00a0985bd455" } } }, "_links": { "self": { "href": "/api/storage/ports/382cb083-4416-11eb-ad1d-00a0985bd455/2c" } } }, { "adapter": { "name": "fcvi_device_0", "wwn": "2100000e1e09d5d2", "type": "fc_vi" }, "port": { "name": "FC port 0/3", "speed": 16 }, "node": { "name": "sti8020mcc-htp-005", "uuid": "382cb083-4416-11eb-ad1d-00a0985bd455", "_links": { "self": { "href": "/api/cluster/nodes/382cb083-4416-11eb-ad1d-00a0985bd455" } } } }, { "adapter": { "name": "2a", "wwn": "21000024ff72c0c8", "type": "fcp_initiator" }, "port": { "name": "FC port 0/1", "speed": 8 }, "node": { "name": "sti8020mcc-htp-006", "uuid": "364fbba8-4416-11eb-8e72-00a098431045", "_links": { "self": { "href": "/api/cluster/nodes/364fbba8-4416-11eb-8e72-00a098431045" } } }, "_links": { "self": { "href": "/api/storage/ports/364fbba8-4416-11eb-8e72-00a098431045/2a" } } }, { "adapter": { "name": "2c", "wwn": "21000024ff72c0ca", "type": "fcp_initiator" }, "port": { "name": "FC port 0/2", "speed": 8 }, "node": { "name": "sti8020mcc-htp-006", "uuid": "364fbba8-4416-11eb-8e72-00a098431045", "_links": { "self": { "href": "/api/cluster/nodes/364fbba8-4416-11eb-8e72-00a098431045" } } }, "_links": { "self": { "href": "/api/storage/ports/364fbba8-4416-11eb-8e72-00a098431045/2c" } } } ], "_links": { "self": { "href": "/api/storage/switches/Brocade_10.226.57.206" } } }
