ONTAP REST API Storage switches endpoints
Retrieving storage switch information
The storage switch GET API retrieves all of the switches in the cluster.
1) Retrieves a list of storage switches from the cluster
The following example shows the response with a list of storage switches in the cluster:
# The API:
/api/storage/switches
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/switches" -H "accept: application/hal+json"
# The response:
"records": [
"name": "Brocade_10.226.57.206",
"href": "/api/storage/switches/Brocade_10.226.57.206"
"name": "Brocade_10.226.57.207",
"href": "/api/storage/switches/Brocade_10.226.57.207"
"name": "Brocade_10.226.57.208",
"href": "/api/storage/switches/Brocade_10.226.57.208"
"name": "Brocade_10.226.57.209",
"href": "/api/storage/switches/Brocade_10.226.57.209"
"num_records": 4,
"href": "/api/storage/switches/"
2) Retrieves a specific storage switch from the cluster
The following example shows the response of the requested storage switch. If there is no storage switch with the requested name, an error is returned.
# The API:
/api/storage/switches/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/switches/Brocade_10.226.57.206" -H "accept: application/hal+json"
# The response:
"domain_id": 5,
"switch_fabric_name": "100050eb1a238892",
"fw_version": "v7.2.1c1",
"ip_address": "10.226.57.206",
"is_director_class": false,
"local": false,
"monitoring_enabled": true,
"model": "Brocade6510",
"role": "subordinate",
"state": "ok",
"symbolic_name": "rtp-fc01-41kk11",
"vendor": "brocade",
"wwn": "100050eb1a1ef7d7",
"power_supply_units": [
"name": "Power Supply #1",
"state": "ok"
"name": "Power Supply #2",
"state": "ok"
"temperature_sensors": [
"name": "SLOT #0: TEMP #1",
"reading": 52,
"state": "ok"
"ports": [
"name": "FC port 0/0",
"mode": "f_port",
"wwn": "200050eb1a1ef7d7",
"enabled": true,
"state": "online",
"speed": 16,
"sfp": {
"type": "small_form_factor",
"transmitter_type": "short_wave_laser",
"serial_number": "HAA2140310058E5"
"name": "FC port 0/1",
"mode": "f_port",
"wwn": "200050eb1a1ef2d7",
"enabled": true,
"state": "online",
"speed": 16,
"sfp": {
"name": "FC port 0/2",
"mode": "f_port",
"wwn": "200050eb1a1ef7d0",
"enabled": true,
"state": "online",
"speed": 16,
"sfp": {
"name": "FC port 0/3",
"mode": "f_port",
"enabled": true,
"state": "online",
"speed": 16,
"sfp": {
"name": "FC port 0/4",
"mode": "f_port",
"enabled": true,
"state": "online",
"speed": 16,
"sfp": {
"name": "FC port 0/5",
"mode": "f_port",
"enabled": true,
"state": "online",
"speed": 16,
"sfp": {
"connections": [
"source_port": {
"wwn": "200050eb1a236efd",
"mode": "f_port"
"peer_port": {
"wwn": "2100000e1e30ac5f",
"connection": "sti8020mcc-htp-006:fcvi_device_1",
"type": "fcvi_adapter",
"unique_id": "38993dc0-4ea1-11eb-9331-00a0985bd455"
"source_port": {
"wwn": "200150eb1a236efd",
"mode": "f_port"
"peer_port": {
"wwn": "21000024ff72c0c9",
"connection": "sti8020mcc-htp-006:2b",
"type": "fcp_adapter",
"source_port": {
"wwn": "200250eb1a236efd",
"mode": "f_port"
"peer_port": {
"wwn": "21000024ff72c0cb",
"connection": "sti8020mcc-htp-006:2d",
"fans": [
"name": "FAN #1",
"speed": 7336,
"state": "ok"
"name": "FAN #2",
"speed": 7336,
"state": "ok"
"paths": [
"adapter": {
"name": "2a",
"wwn": "21000024ff6c4bc0",
"type": "fcp_initiator"
"port": {
"speed": 8
"node": {
"name": "sti8020mcc-htp-005",
"uuid": "382cb083-4416-11eb-ad1d-00a0985bd455",
"href": "/api/cluster/nodes/382cb083-4416-11eb-ad1d-00a0985bd455"
"href": "/api/storage/ports/382cb083-4416-11eb-ad1d-00a0985bd455/2a"
"adapter": {
"name": "2c",
"wwn": "21000024ff6c4bc2",
"port": {
"speed": 8
"node": {
"href": "/api/storage/ports/382cb083-4416-11eb-ad1d-00a0985bd455/2c"
"adapter": {
"name": "fcvi_device_0",
"wwn": "2100000e1e09d5d2",
"type": "fc_vi"
"port": {
"speed": 16
"node": {
"adapter": {
"name": "2a",
"wwn": "21000024ff72c0c8",
"port": {
"speed": 8
"node": {
"name": "sti8020mcc-htp-006",
"uuid": "364fbba8-4416-11eb-8e72-00a098431045",
"href": "/api/cluster/nodes/364fbba8-4416-11eb-8e72-00a098431045"
"href": "/api/storage/ports/364fbba8-4416-11eb-8e72-00a098431045/2a"
"adapter": {
"name": "2c",
"wwn": "21000024ff72c0ca",
"port": {
"speed": 8
"node": {
"href": "/api/storage/ports/364fbba8-4416-11eb-8e72-00a098431045/2c"
