REST API reference
View administrative audit logs
Access administrative audit logs through these endpoints to review detailed records of system activities. Use GET requests to retrieve log records containing timestamps, node names, and other relevant information to monitor and analyze your ONTAP environment effectively.
Overview
These APIs return audit log records. The GET requests retrieves all audit log records. An audit log record contains information such as timestamp, node name, index and so on.
Example
Retrieving audit log records
The following example shows the audit log records.
# The API:
/api/security/audit/messages
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit/messages"
# The response:
"records": [
    "timestamp": "2019-03-08T11:03:32-05:00",
    "node": {
      "name": "node1",
      "uuid": "bc9af9da-41bb-11e9-a3db-005056bb27cf",
          "href": "/api/cluster/nodes/bc9af9da-41bb-11e9-a3db-005056bb27cf"
    "index": 4294967299,
    "application": "http",
    "location": "172.21.16.89",
    "user": "admin",
    "input": "GET /api/security/audit/destinations/",
    "state": "pending",
    "scope": "cluster"
"num_records": 1,
    "href": "/api/security/audit/messages"
