View administrative audit logs
Retrieve administrative audit log records to monitor and analyze actions within your ONTAP environment. Use these APIs to obtain detailed information such as timestamps, node names, and user activities.
Overview
These APIs return audit log records. The GET requests retrieves all audit log records. An audit log record contains information such as timestamp, node name, index and so on.
Example
Retrieving audit log records
The following example shows the audit log records.
# The API:
/api/security/audit/messages
# The call:
curl -X GET "https://<cluster-ip>/api/security/audit/messages"
# The response:
"records": [
"timestamp": "2019-03-08T11:03:32-05:00",
"node": {
"name": "node1",
"uuid": "bc9af9da-41bb-11e9-a3db-005056bb27cf",
"href": "/api/cluster/nodes/bc9af9da-41bb-11e9-a3db-005056bb27cf"
"index": 4294967299,
"application": "http",
"location": "172.21.16.89",
"user": "admin",
"input": "GET /api/security/audit/destinations/",
"state": "pending",
"scope": "cluster"
"num_records": 1,
"href": "/api/security/audit/messages"
