View and update cluster web configurations
Use this API to view and modify cluster web configurations, including settings for ports, certificates, and security features. Retrieve current configurations to ensure proper setup, or apply updates to maintain optimal web service functionality across your ONTAP cluster.
Overview
You can use this API to update web services configurations and to retrieve current configurations.
Retrieving the current web services configuration
The cluster web GET API retrieves the current cluster-wide configuration.
Updating the current web services configuration
The cluster web PATCH API updates the current cluster-wide configuration.
Once updated, ONTAP restarts the web services to apply the changes.
When updating the certificate, the certificate UUID of an existing certificate known to ONTAP must be provided. The certificate must be of type "server".
A "client-ca" certificate must be installed on ONTAP to enable "client_enabled".
The following fields can be used to update the cluster-wide configuration:
enabled
http_port
https_port
http_enabled
csrf.protection_enabled
csrf.token.concurrent_limit
csrf.token.idle_timeout
csrf.token.max_timeout
certificate.uuid
client_enabled
ocsp_enabled
Retrieving the cluster-wide web services configuration
# API:
GET /api/cluster/web
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/web" -H "accept: application/hal+json"
# The response:
"enabled": true,
"http_port": 80,
"https_port": 443,
"state": "online",
"http_enabled": false,
"csrf": {
"protection_enabled": true,
"token": {
"concurrent_limit": 500,
"idle_timeout": 900,
"max_timeout": 0
"certificate": {
"uuid": "a3bb219d-4382-1fe0-9c06-1070568ea23d",
"name": "cert1",
"href": "/api/security/certificates/a3bb219d-4382-1fe0-9c06-1070568ea23d"
"client_enabled": false,
"ocsp_enabled": false,
"href": "/api/cluster/web"
Updating the cluster-wide web services configuration
# The API:
PATCH /api/cluster/web
# The call:
curl -X PATCH "https://<mgmt-ip>/api/cluster/web" -d '{ "https_port": 446, "csrf": { "token": { "concurrent_limit": 600 } } }' -H "accept: application/hal+json"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 28 May 2021 09:36:43 GMT
Server: libzapid-httpd
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
Content-Type: application/hal+json
