REST API reference
View and update cluster web configurations
Use this API to retrieve and modify cluster-wide web services configurations. Adjust settings such as HTTP and HTTPS ports, certificate details, and security features to tailor the web interface to your requirements.
Overview
You can use this API to update web services configurations and to retrieve current configurations.
Retrieving the current web services configuration
The cluster web GET API retrieves the current cluster-wide configuration.
Updating the current web services configuration
The cluster web PATCH API updates the current cluster-wide configuration.
Once updated, ONTAP restarts the web services to apply the changes.
When updating the certificate, the certificate UUID of an existing certificate known to ONTAP must be provided. The certificate must be of type "server".
A "client-ca" certificate must be installed on ONTAP to enable "client_enabled".
The following fields can be used to update the cluster-wide configuration:
  • enabled
  • http_port
  • https_port
  • http_enabled
  • csrf.protection_enabled
  • csrf.token.concurrent_limit
  • csrf.token.idle_timeout
  • csrf.token.max_timeout
  • certificate.uuid
  • client_enabled
  • ocsp_enabled
  • hsts.enabled
  • hsts.max_age
Retrieving the cluster-wide web services configuration
# API:
GET /api/cluster/web
# The call:
curl -X GET "https://<mgmt-ip>/api/cluster/web" -H "accept: application/hal+json"
# The response:
"enabled": true,
"http_port": 80,
"https_port": 443,
"state": "online",
"http_enabled": false,
"csrf": {
  "protection_enabled": true,
  "token": {
    "concurrent_limit": 500,
    "idle_timeout": 900,
    "max_timeout": 650
"certificate": {
  "uuid": "a3bb219d-4382-1fe0-9c06-1070568ea23d",
  "name": "cert1",
      "href": "/api/security/certificates/a3bb219d-4382-1fe0-9c06-1070568ea23d"
"client_enabled": false,
"ocsp_enabled": false,
"hsts": {
  "enabled": true,
  "max_age": 31536000
    "href": "/api/cluster/web"
Updating the cluster-wide web services configuration
# The API:
PATCH /api/cluster/web
# The call:
curl -X PATCH "https://<mgmt-ip>/api/cluster/web" -d '{ "https_port": 446, "csrf": { "token": { "concurrent_limit": 600 } } }' -H "accept: application/hal+json"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 28 May 2021 09:36:43 GMT
Server: libzapid-httpd
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 189
Content-Type: application/hal+json
