View NFS client information
Utilize the NFS connected client map endpoints to display detailed client information within your ONTAP environment. These endpoints help you retrieve data such as node and SVM identifiers, server IPs, and client IPs for monitoring and management purposes.
Overview
ONTAP connected clients map functionality is mainly used by the System Manager to display client information.
The following are details of the fields retrieved for the Connected Clients MAP GET API:
node.name: Node name hosting this record, essentially the node hosting the "server_ip". node.uuid: Node UUID hosting this record, essentially the node hosting the "server_ip". svm.name: SVM name to which the "server_ip" belongs to. svm.uuid: SVM UUID to which the "server_ip" belongs to. server_ip: All clients that are connected to this interface are displayed in rows. client_ips: List of client IP addresses connected to the interface.
Example
Retrieving connected client Map information
# The API:
GET /protocols/nfs/connected-client-maps
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/nfs/connected-client-maps?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"records": [
"svm": {
"uuid": "c642db55-b8d0-11e9-9ad1-0050568e8480",
"name": "vs1"
"node": {
"uuid": "cc282893-b82f-11e9-a3ad-0050568e8480",
"name": "vsim1"
"server_ip": "10.140.72.214",
"client_ips": [
"127.0.0.1"
"num_records": 1
