REST API reference
View NFS client information
Access NFS client information to monitor and analyze connections within your ONTAP environment. Use these endpoints to retrieve details such as node and SVM identifiers, server IP addresses, and lists of client IPs.
Overview
ONTAP connected clients map functionality is mainly used by the System Manager to display client information.
The following are details of the fields retrieved for the Connected Clients MAP GET API:
node.name: Node name hosting this record, essentially the node hosting the "server_ip". node.uuid: Node UUID hosting this record, essentially the node hosting the "server_ip". svm.name: SVM name to which the "server_ip" belongs to. svm.uuid: SVM UUID to which the "server_ip" belongs to. server_ip: All clients that are connected to this interface are displayed in rows. client_ips: List of client IP addresses connected to the interface.
Example
Retrieving connected client Map information
# The API:
GET /protocols/nfs/connected-client-maps
# The call:
curl -X GET "https://<cluster-mgmt-ip>/api/protocols/nfs/connected-client-maps?return_timeout=15&return_records=true" -H "accept: application/json"
# The response:
"records": [
   "svm": {
     "uuid": "c642db55-b8d0-11e9-9ad1-0050568e8480",
     "name": "vs1"
   "node": {
     "uuid": "cc282893-b82f-11e9-a3ad-0050568e8480",
     "name": "vsim1"
   "server_ip": "10.140.72.214",
   "client_ips": [
     "127.0.0.1"
 "num_records": 1
