Cluster MetroCluster interconnects endpoint overview
Overview
You can use this API to retrieve and display relevant information pertaining to MetroCluster interconnect status. The /cluster/metrocluster/interconnects
endpoint returns a list of all the interconnects in MetroCluster and their status. Each individual interconnect can be queried individually using the /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
endpoint. You can also use this API to modify relevant information related to MetroCluster interconnect. These include address, netmask, and gateway. Modify a MetroCluster interconnect using the /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
endpoint.
Retrieving MetroCluster interconnects
GET https://<mgmt-ip>/api/cluster/metrocluster/interconnects { "records": [ { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "ha", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0f" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "ha", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0g" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "dr", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0f" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "dr", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0g" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "aux", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0f" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "aux", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0g" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "ha", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0f" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "ha", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0g" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "dr", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0f" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "dr", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0g" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "aux", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0f" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "aux", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0g" } } } ], "num_records": 12, "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects" } } }
Retrieves information about a specific MetroCluster interconnect
https://<mgmt-ip>/api/cluster/metrocluster/interconnects/774b4fbc-86f9-11e9-9051-005056825c71/aux/e0f { "node": { "name": "cluster1_01", "uuid": "46147363-9857-11e9-9a55-005056828eb9", "_links": { "self": { "href": "/api/cluster/nodes/46147363-9857-11e9-9a55-005056828eb9" } } }, "partner_type": "aux", "adapter": "e0f", "state": "up", "type": "iwarp", "interfaces": [ { "address": "10.2.3.5", "netmask": "255.255.255.0" } ], "mirror": { "state": "online", "enabled": true }, "multipath_policy": "static_map", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/46147363-9857-11e9-9a55-005056828eb9/ha/e0f" } } }
This example shows how to modify the network address assigned to the home port. Fields required: address.
curl -X PATCH https://<mgmt-ip>/api/cluster/metrocluster/interconnects/3e1bfd38-ffd2-11eb-bcb7-005056aceaa9/ha/e0g -d '{"interfaces": [{"address": "1.2.3.4"}]}'
PATCH Response
HTTP/1.1 200 OK Cache-Control: no-cache,no-store,must-revalidate Connection: close Date: Fri, 20 Aug 2021 21:58:36 GMT Server: libzapid-httpd Content-Length: 3 Content-Type: application/hal+json X-Content-Type-Options: nosniff { }
This example shows how to modify the netmask assigned to the interface. Be sure to change to a valid subnet. Fields required: netmask.
curl -X PATCH https://<mgmt-ip>/api/cluster/metrocluster/interconnects/3e1bfd38-ffd2-11eb-bcb7-005056aceaa9/ha/e0g -d '{"interfaces": [{"netmask": "2.2.2.2"}]}'
PATCH Response
HTTP/1.1 200 OK Cache-Control: no-cache,no-store,must-revalidate Connection: close Date: Fri, 20 Aug 2021 22:11:35 GMT Server: libzapid-httpd Content-Length: 3 Content-Type: application/hal+json X-Content-Type-Options: nosniff { }
This example shows how to modify the gateway assigned to the interface. Please make sure to update it on the switch/router first. Assuming it is a new one, the new gateway and IP address must reside in the same subnet range as the interface IP address. Fields required: gateway.
curl -X PATCH https://<mgmt-ip>/api/cluster/metrocluster/interconnects/3e1bfd38-ffd2-11eb-bcb7-005056aceaa9/ha/e0g -d '{"interfaces": [{"gateway": "1.2.3.4"}]}'
PATCH Response
