REST API reference
Cluster metrocluster interconnects endpoint overview
Overview
You can use this API to retrieve and display relevant information pertaining to MetroCluster interconnect status. The /cluster/metrocluster/interconnects endpoint returns a list of all the interconnects in MetroCluster and their status. Each individual interconnect can be queried individually using the /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter} endpoint.
Retrieving MetroCluster interconnects
GET https://<mgmt-ip>/api/cluster/metrocluster/interconnects
  "records": [
          "node": {
              "name": "cluster1_01",
              "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931",
                      "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931"
          "partner_type": "ha",
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0g"
          "node": {
          "partner_type": "dr",
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0g"
          "node": {
          "partner_type": "aux",
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0g"
          "node": {
              "name": "cluster1_02",
              "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b",
                      "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b"
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0g"
          "node": {
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0g"
          "node": {
          "adapter": "e0f",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0f"
          "node": {
          "adapter": "e0g",
                  "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0g"
  "num_records": 12,
          "href": "/api/cluster/metrocluster/interconnects"
Retrieves information about a specific MetroCluster interconnect
https://<mgmt-ip>/api/cluster/metrocluster/interconnects/774b4fbc-86f9-11e9-9051-005056825c71/aux/e0f
  "node": {
      "uuid": "46147363-9857-11e9-9a55-005056828eb9",
              "href": "/api/cluster/nodes/46147363-9857-11e9-9a55-005056828eb9"
  "adapter": "e0f",
  "state": "up",
  "type": "iwarp",
          "href": "/api/cluster/metrocluster/interconnects/46147363-9857-11e9-9a55-005056828eb9/ha/e0f"
