Cluster MetroCluster interconnects endpoint overview
Overview
You can use this API to retrieve and display relevant information pertaining to MetroCluster interconnect status. The /cluster/metrocluster/interconnects
endpoint returns a list of all the interconnects in MetroCluster and their status. Each individual interconnect can be queried individually using the /cluster/metrocluster/interconnects/{node.uuid}/{partner_type}/{adapter}
endpoint.
Retrieving MetroCluster interconnects
GET https://<mgmt-ip>/api/cluster/metrocluster/interconnects { "records": [ { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "ha", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0f" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "ha", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/ha/e0g" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "dr", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0f" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "dr", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/dr/e0g" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "aux", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0f" } } }, { "node": { "name": "cluster1_01", "uuid": "6fead8fe-8d81-11e9-b5a9-005056826931", "_links": { "self": { "href": "/api/cluster/nodes/6fead8fe-8d81-11e9-b5a9-005056826931" } } }, "partner_type": "aux", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/6fead8fe-8d81-11e9-b5a9-005056826931/aux/e0g" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "ha", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0f" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "ha", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/ha/e0g" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "dr", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0f" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "dr", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/dr/e0g" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "aux", "adapter": "e0f", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0f" } } }, { "node": { "name": "cluster1_02", "uuid": "f5435191-8d81-11e9-9d4b-00505682dc8b", "_links": { "self": { "href": "/api/cluster/nodes/f5435191-8d81-11e9-9d4b-00505682dc8b" } } }, "partner_type": "aux", "adapter": "e0g", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/f5435191-8d81-11e9-9d4b-00505682dc8b/aux/e0g" } } } ], "num_records": 12, "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects" } } }
Retrieves information about a specific MetroCluster interconnect
https://<mgmt-ip>/api/cluster/metrocluster/interconnects/774b4fbc-86f9-11e9-9051-005056825c71/aux/e0f { "node": { "name": "cluster1_01", "uuid": "46147363-9857-11e9-9a55-005056828eb9", "_links": { "self": { "href": "/api/cluster/nodes/46147363-9857-11e9-9a55-005056828eb9" } } }, "partner_type": "ha", "adapter": "e0f", "state": "up", "type": "iwarp", "_links": { "self": { "href": "/api/cluster/metrocluster/interconnects/46147363-9857-11e9-9a55-005056828eb9/ha/e0f" } } }
