REST API reference
Create or retrieve filter rules
Manage rules within a filter to evaluate and determine event matches. Use these endpoints to create or retrieve rules associated with specific filters.
Overview
Manages the list of rules associated with a specific filter. A filter contains a list of rules that are evaluated to determine whether an event matches the filter. When a rule matches an event, the filter is considered a match. See the documentation for /support/ems/filters for details on the various properties in a rule.
Retrieving the collection of rules connected to a filter
# The API:
GET /api/support/ems/filters/{name}/rules
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events/rules" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
    "index": 1,
        "href": "/api/support/ems/filters/no-info-debug-events/rules/1"
    "index": 2,
        "href": "/api/support/ems/filters/no-info-debug-events/rules/2"
"num_records": 2,
    "href": "/api/support/ems/filters/no-info-debug-events/rules"
Creating a new rule under an existing filter
Note The absence of a position index appends the rule to the end of the list.
# The API:
POST /api/support/ems/filters/{name}/rules
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filter_rules_post.txt"
test_ems_filter_rules_post.txt(body):
# JSON Body
"type": "include",
"message_criteria": {
  "name_pattern": "wafl.*",
  "severities": "error,informational"
# The response:
201 Created
