Create or retrieve filter rules
Manage the list of rules within a specific filter to determine event matches. Use these endpoints to create or retrieve rules that evaluate whether an event aligns with the filter criteria.
Overview
Manages the list of rules associated with a specific filter. A filter contains a list of rules that are evaluated to determine whether an event matches the filter. When a rule matches an event, the filter is considered a match. See the documentation for /support/ems/filters for details on the various properties in a rule.
Retrieving the collection of rules connected to a filter
# The API:
GET /api/support/ems/filters/{name}/rules
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events/rules" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"records": [
"index": 1,
"href": "/api/support/ems/filters/no-info-debug-events/rules/1"
"index": 2,
"href": "/api/support/ems/filters/no-info-debug-events/rules/2"
"num_records": 2,
"href": "/api/support/ems/filters/no-info-debug-events/rules"
Creating a new rule under an existing filter
The absence of a position index appends the rule to the end of the list. |
# The API:
POST /api/support/ems/filters/{name}/rules
# The call:
curl -X POST "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filter_rules_post.txt"
test_ems_filter_rules_post.txt(body):
# JSON Body
"type": "include",
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "error,informational"
# The response:
201 Created
