Delete an application and all associated data
Deletes an application and all associated data, removing everything created with the application, such as volumes, LUNs, NFS export policies, CIFS shares, and initiator groups. This action frees up resources used by the application when it's no longer needed.
HTTP method and endpoint
DELETE /application/applications/{uuid}
Introduced in
ONTAP 9.6
Warning - this deletes it all, including your data
This deletes everything created with the application, including any volumes, LUNs, NFS export policies, CIFS shares, and initiator groups. Initiator groups are only destroyed if they were created as part of an application and are no longer in use by other applications.
Learn more
uuid |
string |
path |
True |
Application UUID |
delete_data |
boolean |
query |
False |
By default, deleting an application deletes all of the application's data. By setting this parameter to "false", the application's data is preserved, but can no longer be managed through application APIs.
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
