REST API reference
Delete an application and all associated data
Deletes an application and all associated data, including volumes, LUNs, NFS export policies, CIFS shares, and initiator groups, when they are no longer needed. Use this endpoint to remove an entire application setup from your system.
HTTP method and endpoint
DELETE /application/applications/{uuid}
Introduced in
ONTAP 9.6
Warning - this deletes it all, including your data
This deletes everything created with the application, including any volumes, LUNs, NFS export policies, CIFS shares, and initiator groups. Initiator groups are only destroyed if they were created as part of an application and are no longer in use by other applications.
uuid
string
path
True
Application UUID
delete_data
boolean
query
False
By default, deleting an application deletes all of the application's data. By setting this parameter to "false", the application's data is preserved, but can no longer be managed through application APIs.
  • Introduced in: 9.8
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
