Delete a consistency group Snapshot copy
Deletes a Snapshot copy of a consistency group when you need to remove an outdated or unnecessary snapshot, freeing up storage space and simplifying snapshot management.
HTTP method and endpoint
DELETE /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.10
consistency_group.uuid |
string |
path |
True |
The unique identifier of the Snapshot copy of the consistency group to delete. |
uuid |
string |
path |
True |
Snapshot copy UUID |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
