REST API reference
Delete a consistency group snapshot
Deletes a snapshot of a consistency group to remove unnecessary or outdated data.
HTTP method and endpoint
DELETE /application/consistency-groups/{consistency_group.uuid}/snapshots/{uuid}
Introduced in
ONTAP 9.10
string
path
True
The unique identifier of the snapshot of the consistency group to delete.
uuid
string
path
True
Snapshot UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53412007
Failed to delete the snapshot because it has not expired or is locked.
53412008
Failed to delete the consistency group snapshot because it is currently used as a reference for a replication relationship.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
