Remove a DR group from a MetroCluster IP configuration
Removes a disaster recovery (DR) group from an existing MetroCluster IP configuration. Use this operation when you need to update or decommission the current DR setup.
HTTP method and endpoint
DELETE /cluster/metrocluster/dr-groups/{id}
Introduced in
ONTAP 9.8
Usage notes
Remove the DR group from the current MetroCluster over IP configuration specified by the DR group id.
Related ONTAP commands
metrocluster configuration-settings dr-group delete
id |
string |
path |
True |
return_timeout |
integer |
query |
False |
fields |
array[string] |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2425734 |
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support. |
2432833 |
Operation is already running. |
2432859 |
Unconfigurint MetroCluster DR Group |
2432860 |
Unmirroring Aggregates |
2432861 |
Unassigning Remote Disks |
2432862 |
Disabling Cluster HA and Storage Failover HA |
2432863 |
Disconnecting and deleting network connections |
2432864 |
Unconfiguring and deleting the DR Group |
2432865 |
Deleting MetroCluster DR Group |
2432866 |
MetroCluster DR Group delete done |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
