REST API reference
Remove a DR group from a MetroCluster IP configuration
DELETE /cluster/metrocluster/dr-groups/{id}
Introduced In: 9.8
Remove the DR group from the current MetroCluster over IP configuration specified by the DR group id.
  • metrocluster configuration-settings dr-group delete
id
string
path
True
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
2425574
Two or more DR groups must be configured to remove a DR group from the MetroCluster configuration.
2425734
An internal error occurred. Wait a few minutes, and try the operation again. For further assistance, contact technical support.
2432833
Operation is already running.
2432859
Unconfiguring MetroCluster DR Group
2432860
Unmirroring Aggregates
2432861
Unassigning Remote Disks
2432862
Disabling Cluster HA and Storage Failover HA
2432863
Disconnecting and deleting network connections
2432864
Unconfiguring and deleting the DR Group
2432865
Deleting MetroCluster DR Group
2432866
MetroCluster DR Group delete done
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
