REST API reference
Delete an NTP key
Deletes an NTP key to manage time synchronization settings in your cluster.
HTTP method and endpoint
DELETE /cluster/ntp/keys/{id}
Introduced in
ONTAP 9.7
  • cluster time-service ntp key delete
id
integer
path
True
Key identifier
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2097186
The key cannot be deleted because it is being used by an NTP server.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
