REST API reference
Delete an NTP key
Deletes an NTP key to manage time synchronization configurations within your ONTAP environment.
HTTP method and endpoint
DELETE /cluster/ntp/keys/{id}
Introduced in
ONTAP 9.7
  • cluster time-service ntp key delete
id
integer
path
True
Key identifier
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2097186
The key cannot be deleted because it is being used by an NTP server.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
