Delete an NTP key
DELETE /cluster/ntp/keys/{id}
Deletes an NTP key.
Related ONTAP commands
cluster time-service ntp key delete
Learn more
id |
integer |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097186 |
The key cannot be deleted because it is being used by an NTP server. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
