REST API reference
Delete a service policy for network interfaces
Removes a service policy for network interfaces when it is no longer needed, ensuring that your network configurations remain up to date.
HTTP method and endpoint
DELETE /network/ip/service-policies/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes a service policy for network interfaces.
uuid
string
path
True
UUID of the service policy
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
53281927
Service policies owned by the system cannot be deleted.
53281928
Service policies assigned to LIFs cannot be deleted.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
