REST API reference
Delete a service policy for network interfaces
Deletes a service policy for network interfaces to remove configurations that are no longer needed.
HTTP method and endpoint
DELETE /network/ip/service-policies/{uuid}
Introduced in
ONTAP 9.8
  • network interface service-policy delete
uuid
string
path
True
UUID of the service policy
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621740
An unexpected error when trying to determine whether the target Vserver was locked or not on this cluster.
53281927
Service policies owned by the system cannot be deleted.
53281928
Service policies assigned to LIFs cannot be deleted.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
