Deletes the local user, active directory user and/or active directory group from the specified local group and svm
learn more
doc /protocols/cifs/local-groups/{svmuuid}/{local_cifs_groupsid}/members](#docs-nas-protocols_cifs_local-groups_{svmuuid}_{local_cifs_groupsid}_members)
DELETE /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members/{name}
Introduced In: 9.10
Deletes the local user, Active Directory user and/or Active Directory group from the specified local group and SVM.
Related ONTAP commands
vserver cifs users-and-groups local-group remove-members
local_cifs_group.sid |
string |
path |
True |
Local group SID |
name |
string |
path |
True |
Member name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error ontap error response codes | error code | description | | ---------- | ----------- | | 655673 | failed to resolve the member to be deleted from the specified group. | | 655719 | failed to delete a member from the specified group. the error code returned details the failure along with the reason for the failure. take corrective actions as per the specified reason. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
