REST API reference
Delete a local user, or Active Directory user or group from a local group and SVM
Removes a local user, Active Directory user, or Active Directory group from a specified local group and SVM. Use this endpoint to manage group membership and access controls within your storage environment.
HTTP method and endpoint
DELETE /protocols/cifs/local-groups/{svm.uuid}/{local_cifs_group.sid}/members/{name}
Introduced in
ONTAP 9.10
Usage notes
Deletes the local user, Active Directory user and/or Active Directory group from the specified local group and SVM.
  • vserver cifs users-and-groups local-group remove-members
string
path
True
Local group SID
name
string
path
True
Member name
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error ontap error response codes | error code | description | | ---------- | ----------- | | 655673     | failed to resolve the member to be deleted from the specified group. | | 655719     | failed to delete a member from the specified group. the error code returned details the failure along with the reason for the failure. take corrective actions as per the specified reason. |
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
