REST API reference
Delete a CIFS share
DELETE /protocols/cifs/shares/{svm.uuid}/{name}
Introduced In: 9.6
Deletes a CIFS share.
  • vserver cifs share delete
name
string
path
True
Share Name
svm.uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655393
Standard admin shares cannot be removed
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
