Deletes a cifs share
learn more
doc /protocols/cifs/shares](#docs-nas-protocols_cifs_shares)
DELETE /protocols/cifs/shares/{svm.uuid}/{name}
Introduced In: 9.6
Deletes a CIFS share.
Related ONTAP commands
vserver cifs share delete
Learn more
name |
string |
path |
True |
Share Name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655393 |
Standard admin shares cannot be removed |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
