REST API reference
Deletes the s3 user configuration of an svm
learn more
  • [doc /protocols/s3/services/{svmuuid}/users](#docs-object-store-protocols_s3_services_{svmuuid}_users)
DELETE /protocols/s3/services/{svm.uuid}/users/{name}
Introduced In: 9.7
Deletes the S3 user configuration of an SVM.
  • vserver object-store-server user delete
name
string
path
True
User name
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
