REST API reference
Delete an S3 user configuration
Deletes an S3 user configuration for a specific SVM, removing the associated settings and permissions.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Deletes the S3 user configuration of an SVM.
  • vserver object-store-server user delete
name
string
path
True
User name
svm.uuid
string
path
True
Status: 200, Ok
Status: Default, Error
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
