REST API reference
Delete portset network interfaces
Deletes a network interface from a portset, removing it from the associated configuration for SAN protocols.
HTTP method and endpoint
DELETE /protocols/san/portsets/{portset.uuid}/interfaces/{uuid}
Introduced in
ONTAP 9.9
  • lun portset remove
portset.uuid
string
path
True
The unique identifier of the portset.
uuid
string
path
True
The unique identifier of the network interface in the portset.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374906
A specified network interface was not found.
5374908
The portset specified in the URI does not exist.
5374916
The specified network interface is not in the portset.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
