Delete portset network interfaces
Deletes a network interface from a portset when you need to modify or manage portset configurations.
HTTP method and endpoint
DELETE /protocols/san/portsets/{portset.uuid}/interfaces/{uuid}
Introduced in
ONTAP 9.9
Related ONTAP commands
lun portset remove
Learn more
portset.uuid |
string |
path |
True |
The unique identifier of the portset. |
uuid |
string |
path |
True |
The unique identifier of the network interface in the portset. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374906 |
A specified network interface was not found. |
5374908 |
The portset specified in the URI does not exist. |
5374916 |
The specified network interface is not in the portset. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
