REST API reference
Delete a vVol binding
Deletes a virtual volume (vVol) binding to manage the connections between logical unit numbers (LUNs). Use this endpoint when you need to remove or adjust the reference count for the binding between specific LUNs.
HTTP method and endpoint
DELETE /protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes a vVol binding. The binding between any two specific LUNs is reference counted. When a binding is deleted, the binding count is decremented, but the LUNs remain bound if the resultant reference count is greater than zero. When the binding count reaches zero, the binding is destroyed.
  • lun bind destroy
string
path
True
The unique identifier of the class protocol_endpoint LUN.
vvol.uuid
string
path
True
The unique identifier of the class vvol LUN.
delete_all_references
boolean
query
False
Forces deletion of the binding regardless of the reference count value.
  • Default value:
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The vVol binding was not found because the protocol endpoint or vVol LUN was not found. Use to the target property of the error object to differentiate between the protocol endpoint LUN and the vVol LUN.
5374926
The vVol binding was not found.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
