Delete a vVol binding
Deletes a vVol binding to manage the reference count between two LUNs. Use this operation when you need to adjust or remove the relationship between LUNs as part of your storage management tasks.
HTTP method and endpoint
DELETE /protocols/san/vvol-bindings/{protocol_endpoint.uuid}/{vvol.uuid}
Introduced in
ONTAP 9.10
Usage notes
The binding between any two specific LUNs is reference counted. When a binding is deleted, the binding count is decremented, but the LUNs remain bound if the resultant reference count is greater than zero. When the binding count reaches zero, the binding is destroyed.
Related ONTAP commands
lun bind destroy
Learn more
protocol_endpoint.uuid |
string |
path |
True |
The unique identifier of the class |
vvol.uuid |
string |
path |
True |
delete_all_references |
boolean |
query |
False |
Forces deletion of the binding regardless of the reference count value.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The vVol binding was not found because the protocol endpoint or vVol LUN was not found. Use to the |
5374926 |
The vVol binding was not found. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
