Delete a multi-admin-verify rule
DELETE /security/multi-admin-verify/rules/{owner.uuid}/{operation}
Introduced In: 9.11
Deletes a multi-admin-verify rule.
owner.uuid |
string |
path |
True |
operation |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262310 |
System rules cannot be deleted or have their query modified. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
