REST API reference
Delete a multi-admin-verify rule
Deletes a multi-admin-verify rule to remove it from the system configuration. This action is typically performed when a rule is no longer needed or requires replacement.
HTTP method and endpoint
DELETE /security/multi-admin-verify/rules/{owner.uuid}/{operation}
Introduced in
ONTAP 9.11
owner.uuid
string
path
True
operation
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262310
System rules cannot be deleted or have their query modified.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
