Delete a FlexCache volume
Deletes a FlexCache volume when you need to remove it from your ONTAP system. Once offlined, the volume is permanently removed to free up resources or manage storage configurations.
HTTP method and endpoint
DELETE /storage/flexcache/flexcaches/{uuid}
Introduced in
ONTAP 9.6
Usage notes
If a FlexCache volume is online, it is offlined before deletion.
Related ONTAP commands
volume flexcache delete
Learn more
uuid |
string |
path |
True |
Unique identifier of the FlexCache. |
return_timeout |
integer |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846879 |
The specified volume UUID is not a FlexCache volume |
66846731 |
Failed to delete the FlexCache volume |
524546 |
Failed to delete the FlexCache volume because the FlexCache volume is not unmounted |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
